Issue with setting Dates to the Future
Arvin M April 19, 2024
Hi All,
We have date fields for which we sometimes need to set to the future (12-31-2099). When this is done and the issue is refreshed, it goes back to 12-31-1999.
Is this issue prevalent for other customers as well? Is there a workaround?
Thank you very much.
Warm Regards,
AM
Jack Brickey
Hi have seen similar posts in the past. Does this happen with the due date field or only custom date fields? I'm trying to recall if there is some known limitation. I can try testing myself in a bit if I know more specifics about where you're seeing this. I did do a quick test on the due date and it seems to work fine.
