Updating the issue's position failed
The requested board cannot be viewed because it either does not exist or you do not have permission to view it.
Yes, that happens when you do not have permission to use the board in question.
i have all permissions but still getting this erorr
The error is stating that you do not have permission to view the board. This might be a bug, but it's much more likely that it is simply accurate, and you do not have the permission to see the board.
Have you tried viewing the board?
i have Admin access and also have board access
And when you are on that board, can you change the issue?
Yes, I can change the issues
