JSON syntax errors in automation
Vamsi Krishna Panthulu
hi All
I am trying to create a automation rule that will create tickets on a scheduled basis.  couple of mandatory fields in the ticket form are not available in the "choose fields to set" dropdown in the automation.  Hence i am using the advanced optoin available which is asking for a json format.  I have provided the below parameters however the automation keeps failing for syntax i think.  I have tried validating my json script online tools and they say it does not have any error.
"fields": {
"customfield_10213": "Azure",
"Module Classification": {
"value": "Unified Archival Admin",
"child": {"value": "Reports"}
I am getting the below error:
Error creating issue
Can not instantiate value of type [simple type, class com.atlassian.jira.issue.fields.rest.json.beans.CustomFieldOptionJsonBean] from JSON String; no single-String constructor/factory method (customfield_10213)
Kseniia Trushnikova
Hi @Vamsi Krishna Panthulu,
What is the type of the field "customfield_10213"?
Instead of "customfield_10213": "Azure", try to use this:
"fields": {
"customfield_10213": { "value": "Azure" }
Thank you @Kseniia Trushnikova that worked for me.
I am trying to also define the request type for the new ticket in JSON.  however, it is not working as expected and throwing the below error.  I have used the field actual name as well as cf code, but still see the same issue.  the value i am providing for this field is a valid request type in this project.  any advise please.  10010 is the request type field.
"fields": {
"value": "Azure"
"customfield_10010": "System Consulting",
"child": {
"value": "Reports"
Invalid customer request value (customfield_10010)
Kseniia Trushnikova
@Vamsi Krishna Panthulu, use ID instead of a request type name, for example:
"customfield_10010": "5"
The other way is to use the action Edit Request type mentioned in this question.
thank you i used the option of value as number and it worked like a charm.
Like Kseniia Trushnikova likes this
