Jira Automation for Asset Updates
Matthew Berzinskas
January 14, 2025 edited
Hello - I am trying to create a Global Automation that triggers when a specific asset attribute is updated.
I have found, and am familiar with checking for when an object is updated in general, and then retrieving the values from a webhook response, but I can't seem to find a way to conditionally check what attribute was updated.
For example, if an asset's attribute like "First Name" gets updated, I wanted to perform some action.
I've tried extracting the value of
{{webhookResponse.body.first.affectedAttribute}}
And then comparing it, like:
equals
"First Name"
But this always seems to fail. Is there a better, or working, way to check for which field of an Asset/Object was updated?
Following this article:
https://confluence.atlassian.com/jirakb/assets-automation-trigger-rule-based-on-attribute-update-for-jsm-cloud-1456179255.html
The above should work, but it always fails. Is there some special formatting in the attribute names?
Matthew Berzinskas
It didn't like the quotes in the value I was comparing against.
Simple mistake I guess.
