Is there a way to setup an automation that does the following steps:
1) Uses saved filter to export the data into an excel file - automatically.
2) Then, stores the excel file into a SharePoint.
Rajan
Hi Rajan,
Unfortunately you cannot do this from Jira Automation.
Some alternatives that you can use:
-Use Jira Filter with Schedule ( daily you will receive via email the CSV from jira)
-You can build a script (eg. Python)
-You can use RPA
-You can connect the filter to Excel and build a macro in Excel
Hope this will help.
