Jira Standard Plan VS Premium Plan
Eitzaz Haider
Dear Friends,
I’m currently exploring the Premium plan and assessing its feasibility by understanding why I might need it instead of sticking with the existing Standard package (Cloud). I believe there are three to four key factors that are essential to consider in deciding whether to upgrade to Premium or remain with Standard.
The first factor is the team size (number of users that can be added), followed by storage capacity, and thirdly, automation capabilities.
I have a few questions regarding these three major points, and please feel free to suggest any other considerations I should keep in mind.
Q1) I have a centralized Jira product on the Standard plan, but it indicates that I can only add 50 users per JSM and Confluence. Even on the official pricing page, it mentions that this is a limitation of the Standard plan.
Q2) I checked the storage, and it appears to be sufficient, so this is a positive aspect for the Standard plan.
Q3) The main point of concern is automation. How can I access and analyze the usage statistics for all automation rules?
Additionally, please feel free to suggest any other points I should consider.
2 accepted
Susan Waldrip
Hi @Eitzaz Haider , regarding the 50-user limit, in the screenshot you included (thank you!) it shows you've used 46 out of 50 paid licenses for one product and 48 out of 50 paid licenses for the other product. @Carlos Garcia Navarro is correct that you can have up to 50,000 users (in Jira), but you have to pay for them in tiers. You can have as many customers as you want, which are non-licensed users. So if you need more than 50 licensed users (agents, admins), you'll need to pay for the next tier up (which is probably either 75 or 100 licenses).
Eitzaz Haider
Thank you @Susan Waldrip
Hi @Eitzaz Haider ,
I'd like to share this page which I find very descriptive while describing the differences between Jira Standard vs the Premium plans.
To see the automation usage you can use this.
Eitzaz Haider
thank you @Carlos Garcia Navarro . one more point why in standard package it showed me i can add only 50 users even the limit for standard can be more than 50
Eitzaz Haider
Hmm... I'm not sure. The standard plan (and premium too) is for up to 50,000 users for Jira. You could contact Atlassian billing here for specific questions about your account related to billing and licensing: https://www.atlassian.com/company/contact/purchasing-licensing#/
Like # people like this
gh May 12, 2025
Hi all, for Jira Service Management (JSM) is the restriction 20000 users for standard and premium. when more than 20000 agents need access then a enterprise-plan is needed.
https://www.atlassian.com/software/jira/service-management/pricing
the Link also shows the features you can use with premium.
If you want to use these premium features you ideally should have the related ITIl 4 practices  implemented or you may be planning to introduce eg. asset and configuration management or AI-agents....
have a look here to get more inspiration from https://events.atlassian.com/highvelocity/
JSM supports the ITIL 4 specialist practices from ITIL 4 High Velocity. The ITIL 4 Training may be ordered at one of the PeopleCert-Training-Centers. There you can get a deep understanding, which processes are supportet by JSM....
greetings from germany
gabriele
