Key combination “e” does not work
Antonia
September 5, 2025
Jira used to have a keyboard shortcut “e” that allowed you to edit the ticket and assign it to someone, which would then open an editing window. Now, when I press “e” in a work item, nothing happens. How can I set up or activate this keyboard shortcut?
4 votes
Marc - Devoteam
September 5, 2025
Hi @Antonia
The "E" shortcut seems not be working due to the *New Jira issue view* is active in all instances.
For the New Jira issue view, this shortcut is no longer being used and this is a expected behaviour since the issue is shown directly on the screen and you are able to edit it.
Now, you can't disable the *New Jira issue view* and get the "E" back to work.
Also, you can find more information about this feature in the following documentation:
The new Jira issue view - https://confluence.atlassian.com/jiracorecloud/the-new-jira-issue-view-938040503.html
See also JRACLOUD-90965 , but I don't think this will be fixed, due to the new issue view.
Antonia
September 5, 2025
Hi @Marc - Devoteam
oh okay,  thank you.
Like Marc - Devoteam likes this
