×Hello, I have been trying to limit the issue type based on the user group to specific project with no success via Behaviours on Jira ScriptRunner.
Example User belongs to the group JIRAtests should only be available to create issuetypes A and B, while users that do not belong to JIRAtest should be able to create issue types A, B and C
I was trying to achieve this via Scriptrunner behaviors but no success at all.
Hi Rodrigo,
I can confirm that in Jira Cloud, the Behaviours feature does not support Jira Service Management, which means there is no way to restrict issue types on creation in Service Management at this time.
You can see the products and projects types behaviours supports in the documentation page located here.
Also, the example script here shows how to restrict issue types to users in certain groups in supported project types.
I hope this information helps.
Kristian
Hello @Rodrigo Gomez
I think the syntax of your line here is incorrect:
I have modified but seems this is not compatible with Jira Service Management
thanks for the help
In addition to what @Trudy Claspill pointed out on the syntax error, please kept in mind that in JSM what users sees are the Request Types to create his/her issues for your JSM project.
Request Type is based on the IssueType allowed in your project. So are you asking to restrict request types access based on group association? If, take a look at this reference link out of the box for JSM to restrict request type access for issue creation (without using Behavior setup) -
Hope this helps.
Best, Joseph Chung Yin
