×Hi,
Is it possible to load the create screen during workflow transition ?
I'm looking to transition issue into a status and then get the create screen to load so the user can create new issue in another project
Not as described. You could consider using Automation that would trigger based on transition to specific status. I use this to create an issue in a SW dev project when moved into Development.
