Sign up Log in
Logical AND for conditional in form
Raffaele Ziraldo February 28, 2022
I'm creating a form for the service portal through Jira Cloud and I need that some fields are visible only if the value of two previous fields be the desired one.
chrome_vujt9RPx1G.pngIn the image, the last three fields must be visible only if "Complaint reason" is e.g. X and "Product" is e.g. Y or Z. "Complaint reason" and "Product" are always visible.
This "logical AND" with the conditional option of the Sections it seems not possible.
Is there any way to do it?
Karolina Wons_SaaSJet
March 11, 2022
Hello @Raffaele Ziraldo
You might attempt the Jira Cloud Forms and Checklist add-on as a solution. Form condition logic may be configured here to dynamically show or hide fields in custom forms or checklists. This add-on was created by my team, so please contact me if you have any questions.
Hope it helps
Raffaele Ziraldo March 11, 2022
Hi @Karolina Wons_SaaSJet ,
thanks for the suggestion. I would avoid to use a paid add-on for probably one or two fields in our form, but the price of your solution is very affordable (than others similar), so maybe I give a try and I discuss about it in my company.
Greetings
Like German Taroco likes this
Raffaele Ziraldo August 24, 2022
Good morning @Karolina Wons_SaaSJet ,
next month we start the evaluation of some apps to address this request.
I would like to ask you if with your app it is possible to make searching filters on the filed in the form.
Karyna Tyrnavska _SaaSJet
@Raffaele Ziraldo !
I`m a product marketer from SaaSJet team. Unfortunately, filtering isn`t available now.
Mateusz Lisiewicz July 24, 2022
@Raffaele Ziraldoperfect solution for your problem is using of Forms in Jira Cloud :)
PS. now is free on Standard Plan
Édpo César
February 28, 2022
Hi, @Raffaele Ziraldo
So far I've never seen this functionality in JIra. Maybe you can suggest this functionality here.
Raffaele Ziraldo March 1, 2022
I opened an issue on the support portal, but if you think that they spent 8 years to satisfy the request to be able to use dynamic fields on forms...I'm not so confident....
Please, vote for it JSDCLOUD-10999 :)
