Look up issues: priority
Lean Li
Hi!
I'm sending a summary on critical issues to a slack channel but the {{priority.name}}- doesn'r return any value. What could be the problem here? This is my message:
{{#lookupIssues}}
Summary: {{summary}}
Issue: {{URL}}
Priority: {{priority.name}}
Status: {{status.name}}
Lean Li
Hi all!
I managed to solve this by changing the lookup issues to rule against issues in bulk documented here: https://confluence.atlassian.com/automation/run-a-rule-against-issues-in-bulk-993924653.html
This is the syntax:
 {{#Issues}}
Issue: {{URL}}
Tarik Userli January 15, 2025
Thx that works for me too!
Like John Funk likes this
Marc - Devoteam
March 1, 2024
Hi @Lean Li
It should be {{priority.name}}, according to the documentation
find-the-smart-value-for-a-field
Lean Li
Thank you for this response.
Unfortunately this doesn't help either.  The field value is this and with that syntax I'm still getting an empty value.
Marc - Devoteam
March 1, 2024
Hi @Lean Li
Does the issue in the lookup have a priority value?
Otherwise I suggest to reach out to Atlassian Support.
Lean Li
Yes, it does. I will, thank you!
Like Marc - Devoteam likes this
SAzaruddin_mp
Hi Lean Li
{{#lookupIssues}}
Issue: {{URL}}
{{#priority}}
Priority: {{name}}
{{/priority}}
can you check this one it works
Thankyou
Lean Li
Hi SAzaruddin_mp
Thank you for your response! Unfortunately this doesn't work.
The priority is not visible at all in the message now.
