Making Jira Forms only visible for certain users
joey_beekman
September 9, 2022
Can you make the Jira Forms only avaliable for a certain group or an individual user?
a little background with this question;
We have Jira servicedesk, we  have created forms which are only applicable to certain (internal) users.
right now the forms can only be visual to everyone or no one which leaves us with the above question. In order to use the forms we are in need to have this working.
many thanks for your reply.
3 accepted
3 votes
Mikael Sandberg
Hi @joey_beekman,
Currently you cannot make the form only visible to certain users, the only thing you can do is mark it as internal (only visible to JSM agents in the project) or external (makes the form visible via the portal).
joey_beekman
September 9, 2022
Thanks for your answer @Mikael Sandberg
Visible to JSM agents or in the project wouldn't work, because we don't need it for the agents nor all people in the project.
Do you know if it's likely there would  an option developped that allows it?
Mikael Sandberg
I don't, I did a quick search on https://jira.atlassian.com/ and couldn't find any suggestions for this, so you could always create one and add the business case for it.
Matthew Rochman
Hi @Mikael Sandberg
when you say:
"Currently you cannot make the form only visible to certain users, the only thing you can do is mark it as internal (only visible to JSM agents in the project) or external (makes the form visible via the portal). "
Do you mean making the whole service desk internal or external?
Or do you mean there is a feature where you can mark a specific form as "internal" and it is only visible to the agents in the project? This is the outcome we want on our side.
Or did you mean that you basically need a whole project / service desk to be restricted, but can't do it at a form-by-form basis?
Mikael Sandberg - Outreach
@Matthew Rochman each form that you attach to a request can either be internal (only visible to agents) or external (visible to customers and agents).
Joseph Chung Yin
@joey_beekman -
I agreed with what @Mikael Sandberg stated.  You only other option right now is to create a separate JSM project with the implemented forms, and then restrict (control access to the project) access to the specified internal users.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Melanie Timmins
September 30, 2024
This is no longer accurate. In 2024 you can now use restrictions on Request types. Go to the Request type, and there should be a column for Restrictions where you can select the lock symbol to then add the groups that can see the request type.
Chris Matkaris
That is great Melanie! Thanks for letting us know!
@joey_beekman maybe you want to mark Melanie's reply as Accepted Answer?
Like Tessa Tuteleers likes this
Mikael Sandberg
True, you can now set restrictions on request types, but that only works for managed users that belongs to the group(s) that should have access to the request. This does not work for JSM only customers, since they cannot be added to a group.
Like # people like this
