Moving Ticket Between Projects, required fields
Travis Sheppard
November 18, 2019
I have been trying to setup some required fields that need to be filled out when moving a ticket to another project.
We have a "general" helpdesk project that we would like to triage the tickets as they come in. For this example they would be moving it to the Software Support project.
During the move they are reclassifying the ticket from Service Request to Problem
We would like it to check if they have filled out the Software Name, and Software Version field, and if not force them to do it at the time of moving the ticket.
I have tried adding a field validator to the Create Ticket transition but it doesn't seem to prompt for a field when moving.
What are the steps needed to set this up?
Muhammad Ramzan_Atlassian Certified Master_
November 19, 2019
If you want users to fill the required field while moving the ticket from one project to another project.
If you want to move tickets from project A to project B then simply , mark those fields as mandatory on Project B, Jira will not allow users to move tickets untill they put some values
Emily Peterson
July 1, 2020
Hello Muhammad,
I have done the following of making the fields required in Project B shown here.
Then when the ticket starts in Project A and I move it over, it does NOT ask the agent to fill in the required fields
Move 1.png move 2.png move 3.png This is the only article I could find that even mentions Moving the issue, but again it does not prompt the agent to fill out the newly required information before moving the ticket into Project B.
-Emily Peterson
Clifford Hull
@Emily Peterson I know this is old and you might have figured something out but he is telling you to mark them as required under field configurations. Keep in mind that based on your screenshots, I am pretty sure this will make the field required on EVERY form. I am betting this is not your intention. I am looking for an answer to the same question so I will post here if I find anything.
Like • 2 people like this
kammili tejraj September 28, 2021
@Clifford Hull Did u get an answer to this issue
padraik
August 24, 2022
Bump
Crystelle S
January 4, 2024
Quite old but in case you come across this (as I have) it seems the above question around "make the field required on EVERY form" could easily be solved by creating another field configuration for this purpose and using that.
Like • Aleksey Plisko likes this
Aleksey Plisko April 19, 2024
Hello Crystelle,
Can you share a screenshot please ?
Aleksey Plisko April 19, 2024 edited
In your team-managed project, it's not functioning properly due to differing field configurations.
