Multiple Lookup Issues Same Jira Rule
Andre Menezes May 5, 2024
Hello all,
I am trying to build a rule, which I have multiple lookup issues and I need to send the result of these lookup issues in a Slack Message.
So, I am using variables to store the result of the Lookupissues, but, it is not working. I am not sure what is missing. See below the rule:
Also, I am not sure if the text I am adding on the Slack Message is correct, I am trying to write the Jira Hyperlink.
Hello Team, see below the pending tickets:
Pending Tickets:
{% for issue in pendingissues %}
• <{{issue.url}}|{{issue.key}}>
{% endfor %}
Missing Requester
{% for issue in missingrequester %}
{% endfor %}
Jack Brickey
Hi @Andre Menezes ,
  • what do you observe?
  • what does the audit show?
  • Can you add a log action to capture the variables for troubleshooting purposes?
  • Can we simplify to a single variable until you get it working? Just to simplify things.
Hey @Jack Brickey thanks for responding.
So, the rule was triggered, but, the message sent in Slack was empty, without the tickets and with the If statement and codes I added, see below:
Pending Tickets:
{% endfor %}Missing Requester
{% endfor %}
So, my guess is that the lookupissues action may be working, but, the error is on the Slack Message, see the logs - the error is, Error rendering smart-values when executing this rule:
