Need help to setup automation for coping value from Original Estimate to Story points
ajin.piones September 13, 2023
Hi there,
Good day,
I am stuck in a big process where I can't able to move further because of this task.
Requirement:
I need to copy the exact value from Original Estimate to Story Points in JIRA.
The below rule I have been setup but no luck.
Kindly guide me
Teresa_DevSamurai
What is the Smart Value that you put in "Then"
I make this one and it works
When: Issue update
Issue fields condition: Story Points is empty
Then: edit issue fields - Story Points - Smart Value: "{{issue.originalEstimate}}"
I hope this will help you
