Hello community,
I am searching for options to to customize the Help Center Portal for customers on Cloud.
We are using extensive amount of JSM project and I am looking for the way how to regroup them (as for each customer are relevant only few projects) and customize looks and feel of the portal.
I checked already:
Refined - however on cloud, it is not possible to use Insight objects which are important for us
Devinity - it is not very UX friendly, missing the Search option and the option to view last request
Do you know about any other way, how to customize the Portal without lossing the vital parts of it?
Thank you
Have you tried Topics which is the out-of-the-box feature? You can group request types from different service desks into one topic. If your service desks are closed to anyone then this might be a perfect solution for you.
With a 'pure' portal you have more options to extend with other apps like Feature Bundle (change request status by a customer, edit request, etc. )
In the above screenshot, you can see how Topics are configured.
Chris
It's Aleksandra from Deviniti - the vendor of the Theme Extension for JSM Cloud app.
It's great that you decided to give our product a try, and we really appreciate your feedback.
If it comes to the limitations you listed, I'm glad to inform you that the Search option is coming soon. Hopefully, you will find it useful!
We'd also love to learn more about your feedback regarding the overall design of the app and other suggestions you may have. We're always open to all new feature ideas and in case you'd like to discuss the capabilities further, you can always reach out to us by submitting a feature request.
Hope to hear from you soon!
Aleksandra
Hey @Aleksandra Bosacka _Deviniti_ thank you for info. I will try to give you some feedback right after we finish testing. Could you specify when exactly will be Search feature available?
Alena
Thanks in advance for any feedback you could share!
Regarding the Search option, we're estimating to release it by the end of October. I encourage you to watch the app on the Marketplace to receive an update about this upcoming release 🙂
Alternatively, if that's more convenient, you can raise a feature request via our Customer portal and we'll be happy to keep you notified about this improvement directly.
Aleksandra
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →Online forums and learning are now in one easy-to-use experience.
