Hi guys,
while setting up new project I encountered a difficulty with creating an automation rule. Please help /advice if you can.
Rule should do following :
When subtask is moved to status "X"
Then parent issue is moved to status "X" and it copy the value of subtask fields "a","b","c" to parent fields "a","b","c".
Is this even possible ?
Thank you in advanced !
Yes this is possible:
