I created a test ITSM project and populated it with some Services. I then enabled the ITSM features in an existing project and the Services were already populated with the same list of Services from the test project. Is there a way to have Services listed at the project level instead of globally?
The short answer is no, you cannot limit the Services to a specific project.
Thank you for confirming. That seems like a missed opportunity.
Agreed, hopefully that will change once the object scheme in Insight that is used for services gets unlocked so you can add more attributes to them. Then you would be able to limit specific services to specific projects.
