Possible to add responder via automation to an incident ?
Nico Lenaerts
I was wondering if it's possible to add a responder to a newly created incident in JSM through automation rules?
Thanks for anybody that reply ;-)
3 votes
Charlie Misonne
Hi Nico,
This is possible when using the "edit issue" action.
Under "more options" you can add a json to update field. Try this:
"update":{
"customfield_10091":[
"add":[
"ari":"<opsgenie_reference>",
"name":"<name of the team>",
"type":"team",
"avatarUrl":null
Where "customfield_10091" is the ID of your Responders field
If you want to find the value of the placeholders I used you can take an existing ticket where the field has been filled out. The endpoint for that is /rest/api/2/issue/<KEY>
Hope this helps!
Nico Lenaerts
Perfect! it works ;-)
Steve Fournier
What is the ari?  Where can I find this?
Serge Lanteigne January 26, 2022 edited
What should be added as <opsgenie_reference> ?
Charlie Misonne
The easiest way to identify this is by looking it up in an existing Jira ticket you have.
Append this to your Jira URL to fetch all the data of that ticket and search for ari in the response. Reuse that in your automation.
There's probably a way to find it in OpsGenie too but I can't check it right now
Yuly Buenahora
November 24, 2022 edited
Hi @Charlie Misonne Could you help me to understand how I need to build the URL?
I need to use this jason but I haven't been able to find the opsgenie-reference for the opsgenie-team :-(
Tansu Akdeniz
Hi @Nico Lenaerts
Yes, you can create an automation to send a custom reply on create action. Go to JSM project -> project settings -> automation and create a new rule.
Btw, you can also edit default "request created" notification from project settings -> customer notifications.
Nico Lenaerts
Hi @Tansu Akdeniz
Thx for your quick reply!
I just tried to setup sending a "custom reply" by adding a new action, but I can't seem to find the custom reply...
Is it possible to elaborate just a bit more?
Thank you!
Tansu Akdeniz
You can use "Send email" function. Or it is possible to use "Comment on issue" (share with customer visibility) which will send a comment over the original request created mail. It will trigger "Public comment added" system notification.
If it is generic message, as I said before, change the following notification instead of creating a rule (below). Defining a new automation rule makes sense if there will be conditional cases.
Like • Nico Lenaerts likes this
Nico Lenaerts
Hey @Tansu Akdeniz
Maybe I wasn't so clear before, so my apologies!
What I really want to do is to add (in an automated way a responder (team from OpsGenie) whenever a new incident is created like shown here in the screenshot:
I don't want to send an email to person, but my goal is this:
Whenever a responder is added, a new "alert" is created in OpsGenie and the responder will be the owner of this alert. So this is where I want to go to...
Like • Pedro Farinha likes this
