Prevent new projects from inheriting [System] issue types
Mariano
August 6, 2024
Hi! Whenever I create a new project it gets a [System] issue type scheme, this causes my issue types to get all messed up because I keep deleting the [System] ones (I have for example, "Change" instead of "[System] Change".
Whenever I create a project in Cloud, I have no way to prevent this system scheme association from happening, is there a way to avoid this?
Thanks in advance!
Vicknesh Shanmugam
August 6, 2024
Hi Mariano.
You may consider creating projects with shared configuration as mentioned in this documentation:
You might need to create a template project with preferred scheme configuration and make Jira to associate the new projects with the existing configuration when you create a new project.
Vicknesh [ServiceRocket]
FREE
Learn more
