Problems with the automatic creation of Assets Objects due to leading zeros?
Jannick Bettighofer
Hi Community,
Introduction:
New assets objects are to be created through automation. Each object has a unique whitelist ID. Before a new assets object can be created, the next free whitelist ID must be found. A whitelist ID is structured as follows: SW-0001, SW-0002, SW-0003, etc.
Problem:
Now my problem is that the automation does not create a correct whitelist ID.
I tried the following lookup by creating a variable:
{{lookupObjects.max(Whiteliste-ID.substringAfter("SW-").asNumber)}}
In the second step, I then calculate with the variable +1:
SW-{{#=}}{{Whitlist}} + 1{{/}}
Question:
I now have the following problem: either the whitelist ID SW-1 or SW- is generated. Is the problem here with the leading zeros? How should I incorporate these into the lookup/calculation?
Thank you in advance for your help!
Joseph Chung Yin
January 26, 2025
@Jannick Bettighofer -
Based on my experience, you may need to have another variable (string based - 000) where you pre-append it to your whitlist ID (number).  However, this may create another issue where if your whitlist ID ends with double digit (i.e. 10), then the overall SW- value will be setup as SW-00010 instead of SW-0010.
You may want to take your whitlist value convert it to string, then manipulate it as a string first, then store it back to your original whitlist value.  I believe it is an issue with the leading 0's results that you want to achieve.
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
I would also recommend that you should reach out to Atlassian Support (https//support.atlassian.com) for their technical assistance.
Sorry.
Best, Joseph Chung Yin
