Remote Directory Connection no longer working
Alex Bromberek
October 23, 2017 edited
it worked for a couple of days now I get this error
Test Remote Directory Connection
Use this form to test the connection to Microsoft Active Directory (Read/Write) directory 'Active Directory server'.
For extended testing enter the credentials of a user in the remote directory.
Test basic connection : Succeeded
Test retrieve user : Failed
org.springframework.ldap.PartialResultException: nested exception is javax.naming.PartialResultException [Root exception is javax.naming.CommunicationException: domainname.com:389 [Root exception is java.net.ConnectException: Connection timed out: connect]]
Steven de Groot
October 24, 2017
Hey Alex,
From the stack trace, it looks like you are having issues with the user directory configuration. Usually this is solved by disabling the "Follow Referrals" in the advanced section of your User Directory configuration.
You can find more information on this in the following KB:
https://confluence.atlassian.com/jirakb/user-lookups-fail-with-partialresultexceptions-due-to-active-directory-follow-referrals-configuration-235668642.html
Steven
Alex Bromberek
October 24, 2017
thank you that fixed it
Akbar October 10, 2023
Hello @Steven de Groot ,
Can you please explain my case below:
