Request Participant is not showing in Create Issue screen
Sigrid Kviteberg
I'm probably missing a small step, but I can't get the Request Participants field to show in the Create Issue screen:
The field is in the needed screen, but not showing for any user when using the Create button.
Mikael Sandberg
What you see is expected behavior and it has to do with Customer permissions and issue level security. When you use the Create button none of these are set yet, and therefor the request participants field is not visible. Customers can only add participants from the portal or via email, and JSM agents can add participants from the issue view. You can learn more about request participants here.
REG23
It is probably the current situation but not what is expected. JSM agents should be able to add more customers (reporter and participants) to a ticket on the create issue screen and they should receive the email notification about the ticket creation. That is a normal daily situation.
Like karel_mellen likes this
Cameron Loperfido
Looks like this hasn't changed as of 5/11/2023.
