Dear Community,
I am setting up SLA configurations in Jira Service Management (JSM) premium plan and need guidance on handling different ticket categories with multiple calendars.
We have a JSM project where we need to manage SLAs based on:
I would appreciate any best practices, automation suggestions, or alternative approaches that the community has successfully implemented.
Thanks in advance!
Hi @Shasheekant Patel ,
Settings SLA and Goals:
Under your project settings --> SLAs, create required calendars based on working days and time.
Now again go to SLA tab and create the required SLA and in goals section, mention the required JQL to filter issues and map the calendars.
You can create multiple goals and map different SLA to each goals.
Example: in Goals, you can write JQL as
Type = ServiceRequest and product entitlement = ABC --> map to calendar 1 based on priority
Type = ServiceRequest and product entitlement = XYZ --> map to calendar 1
More details about SLA and goals are explained in https://support.atlassian.com/jira-service-management-cloud/docs/create-service-level-agreements-slas/
Dear @Rilwan Ahmed ,
Thank you for your response.
I'd like to highlight the point here that in the Product, I have setup some products and Create 2 fields for manage details in the product i.e. SLA Nature (9-5 business calendar, 24/7 calendar) and ERP ID for Internal mapping.
Can you suggest your input that through these fields how we can fetch the issue in JQL for the goal setup in SLA.
Thanks for your query. This helped me know about Products and Entitlement. I was not aware before of this feature.
Coming to your question "Can you suggest your input that through these fields how we can fetch the issue in JQL for the goal setup in SLA", there are 2 functions in JQL entitlementDetail() and entitlementProduct() which can help you.
Examples:
Create a queue for all issues related to an entitlement where the “Support Level” is “Gold”
entitlement in entitlementDetail("Support Level", "Gold")
Create a queue for all issues related to entitlements for the product “Acme Widget”
entitlement in entitlementProduct("Acme Widget")
More details about this JQL function is in https://support.atlassian.com/jira-software-cloud/docs/jql-functions/#entitlementDetail--
Thank you for your quick response on my query. I appreciate your effort. I'd like to inform you that through the functions I achieved my solution.
Thank you for your time and support once again.
Hi Rilwan,
I hope you are doing well!!
I am looking for some guidance related to smart values and automation rule. I want to setup an rule for the linked issue as -
1. Whenever any tickets will be created by the customer in Jira service project through portal and he selects the product entitlement which has been entitled with his organization/customer, then product entitlement value should be copy on the component in the ticket in issue view.
2. And same time a linked issue must be created in a specific software project and the JSM ticket component must be copy in the software project ticket, and issue should be assign automatically to the components lead in the software project.
Please refer the screenshot attached for the scenario related to Entitlement in portal and Product inside the Jira service project.
Moreover, could you please help me to get the smart value for the Entitlement and its filed value so that I can try different types of automation setup.
I suggest you to ask a new question in the https://community.atlassian.com/ instead of taking this thread too long and it is always beter to have the thread short and simple so that users with similar query will find it useful.
Hi @Shasheekant Patel , based on what you have provided here at all, seems possible and precisely how SLAs work. The one question I have is exactly what you mean by ticket categories here what field or fields will be used to identify ticket categories? If you have not already done so, I recommend that you read the documentation on how to configure SLAs. create-service-level-agreements-slas
please note that you don't associate calendars to categories here but rather you set up your goals and within the goals, you associate whatever calendar you want. For example, in a single goal, you might have multiple calendars such as 24x7 for critical issues and business hours for non-critical.
