SLA smart values not rendering in Jira Automation email template
Sebastian Santoyo
Hello community,
I’m trying to include the SLA duration in an Automation email template in Jira Service Management, but the smart value always renders empty.
Here’s my current template:
Dear customer: {{issue.key}}
We inform you that we received your request, created on {{issue.created.format("dd/MM/yyyy")}}, about {{issue.summary}}.
It is under verification and being processed by the Unit of Banking Operations, assigned to {{assignee.displayName}} and supervised by the Officer {{issue.Oficial.displayName}}.
The maximum time established to complete this request is {{issue.sla."SLA Centro de Excelencia de Servicios".goalDuration.friendly}} working hours.
Our service hours are Monday to Friday from 8:00 a.m. to 3:00 p.m. Requests sent outside this schedule will be processed on the next business day.
The date renders correctly with {{issue.created.format("dd/MM/yyyy")}}.
The assignee also works.
But the SLA value (name: SLA Centro de Excelencia de Servicios) always comes out empty in the email.
What I’ve tried:
{{issue."SLA Centro de Excelencia de Servicios".goalDuration.friendly}}
{{issue."SLA Centro de Excelencia de Servicios".remainingTime.friendly}}
Adding a Re-fetch issue data action before sending the email
Still, the SLA value does not render.
Questions:
What is the correct smart value syntax for including SLA goal/remaining time in an email template?
Is there a timing issue when the rule is triggered on issue creation (before the SLA is calculated)?
Do I need to use a different trigger (e.g., SLA started, scheduled rule) to make SLA values available in the template?
Any guidance would be very appreciated.
Thanks in advance!
Marc - Devoteam
September 17, 2025
Hi @Sebastian Santoyo
When are you sending this email, on issue creation?
Then its correct the values are empty as the SLA calculation is only Done after the issue creation.
You need to de a re-fetch action.
Also you need to use the smart value as;
{{issue.customfield_XXXXX.ongoingCycle.goalDuration.friendly}}
See also this KB article; https://support.atlassian.com/jira/kb/comment-with-sla-smart-value-fails-in-jira-automation-rule/
Sebastian Santoyo
Thanks Marc not working the link alternatives
And the custom field, the ir not a custom field
John Funk
Hi Sebastian,
You might try: {{issue.<sla_name>.ongoingCycle.goalDuration.friendly}}
And here is some more guidance:
https://support.atlassian.com/jira/kb/how-to-find-smart-value-of-sla-component-of-jsm-issues/
Sebastian Santoyo
thanks John did not work
FREE
