ScriptRunner Fast-track transition depend of actual state
Kevin PAGES March 19, 2024
I in my workflow i have a transition avaible for all state, when this transition is used, i need to change the issue state to "OPEN".
I have create a Fast-Track transition with scriptrunner for change the state to open, this is working for all state except when the issue is already in "OPEN" i have an error.
I want to create a condition for check the actual state of the ticket but I don't know how.
Could you help me please ! If you have another idea for doing it I'm also interested but i don't want to do this by an automation.
Thanks !
Sean Chua _Adaptavist_
April 1, 2024
Hey @Kevin PAGES ,
Based on what you mentioned:
I am assuming you are trying to automatically change the "State" (status of the issue) after a period of time. This looks like something which can be done using ScriptRunner for Jira Cloud's Escalation Service: Transition an Issue
You can schedule it to run at a specific schedule (eg: Daily at 12am) for issues found by JQL like:
If you are still unsure, please reach out to us at customersuccess@scriptrunnerhq.com and lets have a call together for a demo/Q&A/etc , or create a Support Ticket with us.
Hope this helps.
Sean
Kevin PAGES April 2, 2024
thanks for your answer, I finaly do it by an other way :)
April 2, 2024
It is good to know that you have resolved it. I'm sure there are a few ways which can be used to meet your needs - as long as you are happy with it and it works for your use-case, that is what matters.
Do you mind sharing abit about what you've done? This would help others if they have the same requirements in the future.
