Scriptrunners jobs for exporting Ticket Data
Taylor Chappell
December 26, 2024
Hello all, trying to get a script going to export some data from couple fields onto a sheet. In the Jobs tab of the ScriptRunner settings, there is a template script for generating an email that I plan on basing this on. The issue I'm having is pulling the data from the fields. It doesn't seem like a Job pulls data from fields in the same way a Listener/Behaviour/etc does (obviously can't use event, current ID/form value, etc). So how can I achieve this?
3 votes
Taylor Chappell
December 26, 2024
import com.atlassian.mail.Email
import groovy.xml.MarkupBuilder
import org.jsoup.Jsoup
import javax.mail.internet.MimeBodyPart
import javax.mail.internet.MimeMultipart
final def filePath = 'tmp'
final def filename = 'Inv_Issue_Data'
final def subject = 'Inventory Data Export'
final def emailAddr = 'emailaddy'
final def language = 'English'
final def country = 'US'
final def location = 'America/Albequirque'
def emailBody = new StringWriter()
def html = new MarkupBuilder(emailBody)
html.html {
    head {
        style (type:'text/css', """
            table {
              border-collapse: collapse;
              width: 100%;
            th, td {
              text-align: left;
              padding: 8px;
            tr:nth-child(even){background-color: #f2f2f2}
            th {
              background-color: #04AA6D;
              color: white;
    body  {
        table  {
            thead  {
                tr  {
                    th 'Issue Key'
                    th 'Issue Summary'
                    th 'Assignee'
                    th 'Reporter'
                    th 'Status'
                Issues.search("project = \"Help Desk\" and resolution != done").each { issues ->
                    def issueKey = issues.key
                    def username = issues.summary
                    def assignee = issues.assignee
                    def reporter = issues.reporter
                    def status = issues.resolution.name
                        tr {
                            td ( issueKey )
                            td ( username )
                            td ( assignee )
                            td ( reporter )
                            td ( status )
def dest = new File("${filePath}/${filename}.csv")
dest.createNewFile()
def fileWriter = new FileWriter("${filePath}/${filename}.csv")
fileWriter.write(generateCSV(emailBody.toString()))
fileWriter.close()
creatMessage(emailAddr, subject, emailBody.toString(), dest)
dest.delete()
final static String generateCSV(String tableDetails) {
    def stringBuilder = new StringBuilder()
    def doc = Jsoup.parseBodyFragment(tableDetails)
    def rows = doc.getElementsByTag('tr')
    rows.each {
        def header = it.getElementsByTag('th')
        def cells = it.getElementsByTag('td')
        header.each { headerCell ->
            stringBuilder.append(headerCell.text().concat(', '))
        cells.each { cell ->
            stringBuilder.append(cell.text().concat(', '))
        stringBuilder.append('\n')
    //Remove empty line in CSV
    def last = stringBuilder.lastIndexOf('\n')
    if (last > 0) {
        stringBuilder.delete(last, stringBuilder.length())
    stringBuilder.toString()
final static creatMessage(String to, String subject, String content, File file) {
    def mailServerManager = ComponentAccessor.mailServerManager
    def mailServer = mailServerManager.defaultSMTPMailServer
    def multipart = new MimeMultipart()
    def body = new MimeBodyPart()
    def mailAttachment = new MimeBodyPart()
    body.setContent(content, 'text/html; charset=utf-8')
    mailAttachment.attachFile(file)
    multipart.addBodyPart(body)
    multipart.addBodyPart(mailAttachment)
    def email = new Email(to)
    email.setSubject(subject)
    email.setMultipart(multipart)
    email.setMimeType("text/html")
    def threadClassLoader = Thread.currentThread().contextClassLoader
    Thread.currentThread().contextClassLoader = mailServer.class.classLoader
    mailServer.send(email)
    Thread.currentThread().contextClassLoader = threadClassLoader
Found the issue I was having. I needed to do the search and iterate on like 54 as a function rather than trying to ID/assign it earlier.
