Search with due date is blank and less than current date
Ramesh Krishnan
when i searched using below jql, shows empty
due IS EMPTY AND due < now()
When i run due date and blank separately its shows record, when i combine doesn't show.
due IS EMPTY - Getting records
due < now() - Getting records
when i join those 2, no records displayed: due IS EMPTY AND due < now()
is wrong with syntax or jql?
September 22, 2025
Hi @Ramesh Krishnan
The suggestions provided to use the OR rather than the AND keyword should work, unless...there is something else incorrect in your query, such as missing parentheses around the Due Date conditions.
If so, please post the entire query you are using to provide more context.  Thank you.
PgM Innovations Support Team
Hi @Ramesh Krishnan,
Use the query below instead:
due IS EMPTY OR due < now()
AND means both conditions should be met.
Regard,
PgM Innovations
Marc - Devoteam
September 22, 2025
Hi @Ramesh Krishnan
Ramesh Krishnan
already  i tried this also, not working
ENTERPRISE
