I am using an automation to send emails to users after Create. It is a Project Scope rule, limited to this one project, ESM. It is failing with an error message in the logs "There is no value set for the field:
Instead of having this automation trigger on issue created, I would instead trigger on incoming webhook and then in the other automation that sets the two fields have that one send a web request to above automation.
Adding a delay to your automation does nothing, the automation only have access the data in the issue when the automation triggers. You would have to do a refresh of the issue in order to get any new values that are added after the automation triggered in order to pick those up.
Thank you. This was a critical piece of information that I was missing and it helps a lot knowing that. I wish Atlassian would add that to their documentation.
Hi @Chelsea , thanks for your post.
Have you tried just putting your email address in the recipient to see if you can get the rule to run?
Another common troubleshooting tip is to use the log action to add the values in the two custom fields so that you can verify that, as you say, the values are being set correctly in time for this rule to run.
Please can you try these things and share the results?
Best wishes
edit - I replied to the wrong comment..and can't delete.
