Set Parent Link When Creating Issue in Post Function
Drew
I have an automation that triggers when an issue in a project transitions to a certain status. In the automation, I'm setting certain fields. One field is Parent Link, which is giving me an error when executing.
The error is a 400 code, with a message of "Incorrect request: {"parent":"data was not an object"}"
The expected value for setting this field is simply an issue key, which is what I'm doing:
One thing to note is that the newly created issue is not in the same project as the issue that triggers the automation, I'm not sure if that matters. Doesn't seem like it should though.
Is the tooltip for the expected value just incorrect?
Reshma Begum {Appfire}
May 6, 2024
Hi @Drew ,
I am Reshma from Appfire, a vendor of JMWE!
Thanks for reporting this issue!
We have identified the bug recently and released a hotfix in the marketplace. It should be working now.
Please give it a try and let us know if you have any questions.
Reshma
Drew
Hi Reshma,
I tested the automation today, it worked exactly as expected! Thank you so much for the update and the quick fix!
Drew
Like • Reshma Begum {Appfire} likes this
David Fischer
Hi @Drew
It looks like a bug in JMWE caused by a recent change in the Jira rest API. You should open a support request with Appfire.
You might also want to try setting the Parent field instead.
John Funk
Hi Drew,
Why are you doing this through JMWE and not just a simple Automation rule?
Also, you should be using the Parent field instead of Parent Link.
All of that being said, those probably have nothing to do with your error. Usually that looks like a Permission thing. And usually because you either don't have Browse Project permissions on the Project that you are trying to create in or you don't have Create issue permissions. Sometimes that has to do with Issue Level Security as well. I would start with investigating all of those.
