I need to set up SLA parameters for my Customer Portals and I have 2 different questions
1. How do I change name from Highest --> Low to Priority 1 to Priority 5.
2. How would you build this SLA tree on the best way. Incident
Priority : Work in progress : First Response : Recurring Feedback : Time for resolution
1 30 min 1 hour 1 hour 1 working day
2 1 hour 2 hours 1 hour 2 Working Days
3 4 hours none none 3 Working Days
4 2 Working Days none none 5 Working Days
Hi Magnus,
You can create new priorities and set a new priority scheme for the project. This will allow you to have specific priorities restricted to the project. As mentioned above by some experts , SLA can be configured based on JQL statements under Project Settings -> SLA
Thankyou!
Bhushan
Hello @Magnus
To change your SLA name you go to project -> settings -> SLAs
Best way to do this SLAs is to create a SLA and add goals
And add goals based on JQL
priority = high goal = 20m
priority = low gaol = 2d
https://confluence.atlassian.com/servicedeskcloud/setting-up-slas-732528967.html
note: if you are wanting to change the terminology of the priority field itself you can do this BUT be aware that it is a system field and ALL project in your instance will change.
Thanks, How do I add holidays for a Country. Do I need to add this manually ? @Jack Brickey or @Bhushan Marathe @Olga Videc
Hi how do I add holidays to my Calender this will have effects on calculation for working days SLA. @Bhushan Marathe @Jack Brickey @Olga Videc
Hello @Magnus
Go to project -> settings -> SLAs
There under Create SLA you will see Calendars
There you can edit existing calendars or add new.
You can edit existing, and add Holidays
Thanks, If i understand this correct after searching around. You need to add all Holidays manually each year. There is no app or other solution for this? @Olga Videc
Unfortunately not as far as I know, or could find, because every country has it's own Hollidays.
