I have this kind of automation that comes by email, I want to do it better somehow, it would be desirable for something like a summary or task description to be displayed there, how can I do this?
Hi @Andrey Ivanov - check out these docs, which list out all of the smart values which you can include in your email.
You can certainly include the description and summary by using {{issue.description}} and {{issue.summary}}.
Hope this helps!
If you are open to using 3rd-party solutions for your case, our app Notification Assistant for Jira can help you with this scenario
It allows you to customize and manage notifications in a way that suits your custom needs like creating fully customizable templates.
Feel free to reach out.
