Team-managed project workflow stuck on an approval
Lukasz
February 21, 2024
I have a Team-managed (!) project with a few request types. My workflow is shared between some of the request types. I defined approval steps (agent assigns approvers, there's a dedicated field to hold the approvers).
When a ticket in one of the request types reaches the approval step, things work as expected.
When a ticket in another type reaches the approval step, it is stuck because it is impossible to add the approver.
This screenshot shows what happens when a ticket in the problematic request type reaches an approval stage - there's no way to add approver. The tooltip links are unhelpful as they point to Company-managed project documentation.
This screenshot shows that for the problematic request type, the "Approvals" field is missing as compared to the request type that works. I can't seem to be able to add the Approvals field manually:
How did I get into this mess, and how do I fix it?
Rilwan Ahmed
Hi @Lukasz ,
From the screenshot you shared, it does not seems to be a team managed project. Instead it is a service management project (I can see SLA settings links).
  1. Go to project settings --> Screens, check if the Approvers fields are in corresponding issue type screens. Mainly the Create Issue Screen
  2. Go to Admin settings --> Issues --> Custom Fields. Search for Approvers field and see if there are any field context setup.
Lukasz
February 21, 2024
Thanks for the prompt response, @Rilwan Ahmed
It almost certainly is a Team-managed JSM project. Here is a screenshot of settings:
FREE
