×Hi team,
Keen to get some insights on the following:
Background
We are currently using Service Desk to manage requests on a global basis. Our teams are located in 2 location - NYC and SG. Within Service Desk, we have also implemented office hours so as to pause SLA if a ticket is created outside of it.
Question
How do I set up a workflow where:
Keen to get your inputs :)
Hello @Idham Zainal
This is possible using Automation.
A simple automation rule can say that if the ticket is not assigned or not worked for 'X' hours, it will be assigned to someone.
This can be further customised and enhanced as per the business requirement.
Let me know if this helps and if you need further help in setting the automation rule.
Kindly accept the answers, if it helps resolve the query.
@Gaurav can you give me an example of how it will look like with Automation? I am playing around with it but unfortunately am unable to find the solution to my request.
While we can look at "not assigned or not worked for X hours", I am looking at more of:
Looking forward to your response!
Hello @Idham Zainal
The rule for this can be set up in the following manner:
This would require 2 separate rules, 1 for each time zone. The below screenshots capture the steps.
Thanks @Gaurav I did the following set up and got this error message:
Hello @Idham Zainal
The JQL can be added to the trigger step itself. Please refer to the below screenshot for this.
