Tempo: Problem Logging Time on Jira Issue
Jane Ellis
Hi Atlassian Community
Trying to log time on a Jira issue, the Tempo integration is having problems.
The Subject field is flickering and the rest of the popup box is unusable. I can add time against the close-out status but not the Tempo screen.
This is happening with Chrome and Edge.
The Tempo timesheet app seems to be fine.
Thanks for any feedback.
Will Schneider
December 20, 2023
Hi
I have the same issue, however when you click cancel 1 time the flickering stops and you can fill in the boxes.
Sam Yan
January 4, 2024 edited
If you have the time blocks on the left expanded, try collapsing it when its flickering.
There is 2 of the same popups showing stacked and overlapping. Its whats causing the flickering, for me at least, when its trying to switch between the 2 of the same popup.
Clicking cancel once closes 1 of the popups, which stops the flickering.
Marc - Devoteam
December 20, 2023
Hi @Jane Ellis
I would raise this topic at Tempo support.
If more people encounter this it could be an issue in the app.
