Transitioning to same status missing
Paul Krueger
August 8, 2023
I have several workflows in which a status is allowed to transition to itself. For example, an issue in the Assigned status could follow the Assign transition and the screen would pop and you could essentially re-assign the issue.
This has worked for a long time, but sometime recently this option is no longer there. It's built into the workflow, but it's not showing as an option in the Status dropdown. Am I missing something here?
5 votes
Thorsten Letschert _Decadis AG_
Hi @Paul Krueger ,
it seems like Atlassian has moved those also to the Actions dropdown, included in the From workflow section:
From my latest knowledge, this only applied to global reflexive transitions. Looks like something was changed (recently?).
Thorsten
Paul Krueger
August 9, 2023
Good find. You're absolutely right (and I wouldn't say I like that change). I've drilled into the heads of agents across our company to reassign using the status button (as opposed to simply changing the assignee), so that's going to be a transition (pun intended) for everyone.
Like # people like this
David Taylor December 13, 2024
this is annoying!
Like andreas_merkel likes this
David Csikkel
April 15, 2025
WTF 🤬 UX of JIRA is worse and worse...
Really such rich company could not afford to hire some expert who knows what good UX is about???
Kris Dewachter
Hi @Paul Krueger ,
are there any conditions applied to the workflow transition ? Those might prevent the transition being visible.
Best regards,
Kris
Paul Krueger
August 8, 2023
No conditions, no validators.
Screenshot 2023-08-08 123942.pngScreenshot 2023-08-08 124128.pngScreenshot 2023-08-08 124118.png
Kris Dewachter
I see the property 'opsbar-sequence' has been set on the transition. I wonder if that might have an impact. Does it help when you remove that property ?
Paul Krueger
August 9, 2023
It does not. I've even tried adding a new transition ("Reassign") instead of reusing the Assign transition and that doesn't work.
Paul Krueger
August 9, 2023
I'll also point out that this isn't project-specific. All of my other projects are exhibiting the same behavior.
