Use dot notation for an assets field in automation
Michael Frade
Making schema changes and trying to migrate existing tickets in a multi select asset custom  field from object type A to Object type B. Label for Object type B is in an attribute of Object Type A called Name.  Have the query to get the impacted issues but getting stuck on the syntax to pull the attribute in Object A to use for a lookup to find the Label in Object B.
Tried {{Cf_123.name}} and other variations with no luck
Any help would be appreciated
Thank you
Jeroen Poismans
In automation you can use smartvalue as follows:
{{issue.customfield-exact-name.attribute}}
So for
Field: Affected Assets
Attribute: Name
It would be:
{{issue.Affected Assets.Name}}
Hope this helps!
Michael Frade
not sure what I was missing but retyped it out in the same format and it worked.
