Use workload in a project
Sébastien PRIOR November 3, 2022
I would like to use the functionality workload. Is it a way to set a calendar for my agents ?Actually I use Jira groups Helpdesk by adding members when they are here, or deleting this agent from my group when he is not here.
Is it possible to set a calendar on agents?
Thanks a lot for your answer
Alex Koxaras -Relational-
Hi @Sébastien PRIOR
By calendar you mean who agent is working and on what days, and automatically to add/remove users from groups?
Exactly ! :)
Out of the box you can't do that for sure.
You should search for an app to do that, BUT things could get a bit complicated if your users are coming from an active directory, and product access is being granted from there.
Like Sébastien PRIOR likes this
