Using match() on webResponse is not working as expected
Svante Gustafsson Björkegren
September 18, 2025
Hey community,
I have run into an issue that gives me a mild headache. I am quite sure I am missing something basic but I cannot identify it.
Background: I have read up an API response that looks like this:
"id": 27653,
"name": "System",
"color": "G200",
"editable": true
"id": 27654,
"name": "Completeness",
"color": "#36B37E",
"editable": true
"id": 27655,
"name": "Application",
"color": "R400",
"editable": true
What I need to do from here is to check if a block including a certain id exists. I have tried this:
{{webResponse.body.id.match("(27653)").size}}
which I expected should have returned 1, but it returns 0.
I have played around with the regex and found that is I match on another element in the block it works fine, like this:
 {{webResponse.body.name.match("(Compl.*)").size}}
returns 1 as expected. So I am thinking that it has to do with the format of the two values, number and string.
Any ideas how to make this .match() function with the numeric attribute id?
Thnx in advance!
// Svante
September 18, 2025
Hi @Svante Gustafsson Björkegren
I wonder if the JSON parsing from the webResponse is detecting the type as number rather than text type.  You could check that by forcing conversion to text with format() prior to the match() function:
{{webResponse.body.id.format("#").match("(27653)").size}}
UPDATED: as the text function apparently does not work with number data.
Marc - Devoteam
September 19, 2025
Hi @Bill Sheboy
I'm like 99% sure the ID in the webResponse is seen as number and not as text.
September 19, 2025
Yes, and...match() operates on text, so conversion with format() will solve this.
Marc - Devoteam
September 18, 2025
What if you would try the following.
{{#webResponse.body}}{{if(equals(id,"27653"), 1)}}{{/}}
