×Hi,
So I need to fetch the n-th object in an Insight multi-select custom field.
The below query works and gives me the correct object
Key = {{issue.customfield_13099.get(0)}}
However I need to use a custom field value (customfield_13113 in this example) in my automation that would, depending on circumstance, get the first, 2nd or 20th object in this Insight multi-select custom field (customfield_13099 in this example).
So far I've tried:
Key = {{issue.customfield_13099.get(issue.customfield_13113.value)}}
Key = {{issue.customfield_13099.get({{issue.customfield_13113}})}}
Key = {{issue.customfield_13099.get({{issue.customfield_13113.value}})}}
Does the list.get() function even accept non-numeric expressions or is it even possible to use smart values within smart values?
Thanks for your help!
I have the same question and I can't find an answer.
