I am trying to find a way to eliminate a redundancy and improve experience for users.
Currently, approvers need to be both in the approver field and a request participant to view the issue they need to approve/reject.
I have seen that I can assign the "Browse issue" permission to the Custom field "Approvers" and then the permission helper says they have access to a test issue.
However, in practice, this doesn't seem to be working.
Is there some other setting that needs to be updated?
Or are there any other best practices here?
Anyone have experience or information on how this should/could work?
What's the problem you're trying to resolve here?
Adding the Approver should give them access to the ticket - is this not happening?
Or do you want their access to be revoked post-approval?
Ste
Hi Stephen, I want approvers to be able to view issues in the portal that they need to review without also having to be a request participant (to save a process step).
Currently, like Mikael noted, users seemingly can only view issues as participants.
Are the Approvers set as Customers in JSM?
I just tested this...
...and it let that user see the ticket for approval, without being added separately as a Request Participant.
So it should work just based on the approval being required.
Just to be clear...
Ste
Approvers can view the request when it is ready for approval, but if you want the approver to have access to the request before and after the approval is needed then they have to be added as request participants unless you are always sharing requests with the organization.
That's why I'm asking for clarification, it depends on the need.
Ste
Hi everyone, thanks for the suggestions. As of now, I am going with the method of approvers having issue access after the approval is ready.
In cases where approvers are known, we are having them added specifically as customers, etc.
The browse project permission would only work if the users have product access to Jira, and they would have to access it from within Jira. For access to the request via the portal the only option is to add them to the request participants field.
So if you need the approvers to have access to the request before and after they have approve the only way to do that is to add them as participants or share the request with the organization.
