View forms in Help Center
Antonia
October 7, 2025
Is it possible for customers to see the attached forms in our Jira Service Management Help Center?
7 votes
Susan Waldrip
Hi Antonia, thanks for your question! You can open a work item in the agent screen, select the three dots menu (right side of the form) and select "Make form external".make form external 1.jpg
If the form is attached via an automation, then in the action "Attach Form" set the Visibility to "External".
Antonia
October 7, 2025
Hi Susan, thank you!
Like Susan Waldrip likes this
