Based on this docs, its only set to Jira Server.
https://confluence.atlassian.com/automation/automation-service-limits-993924705.html
We want to set this param to jira cloud
outgoing.webhook.timeout.ms |
is it possible?
Kinda need your help team.
As mentioned on the documentation, this is not possible for CLOUD instances, only for SERVER.
Please remember to accept this answer in case it helps you resolve your question as it may also help other community members in the future.
Eugenio
Hi @Eugenio Onofre ,
Our use case step is like this:
For that use case, given that it is impossible to setup the time out from Jira side, can you suggest an appropriate way for us to follow?
Thank you
Hi @[deleted]
I would suggest raising a ticket with Atlassian Support to see if it is possible for them to change your timeout settings on their side.
Eugenio
Learn more
