×When creating an custom field in Jira for and Insight Object, we can define the "Filter issue scope (IQL)"
What issue-related smart values can we use here as replacement values?
I was hoping I could use all the smart values described here: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
For example, I tried this (where "Request Type" is an attribute of objectType System):
objectType="System" AND "Request Type"=${issue.Request Type.requestType.name}
The custom field does not return anything in the drop down with these settings.
So far, I have only been able to use values from other fields like ${customfield_12345}
Which smart values are supposed to work in the Filter issue scope (IQL)?
I contacted support and they confirmed my findings: only custom fields that are Insight Object fields can be used as placeholders in Filter issue scope (IQL).
See this existing feature request and vote if it's relevant for you:
Request Type smart value is associated with JSM request type and not for Insight schema, thus you cannot use it for your case.
Here is the link on smart values as related to Insight Schema - https://support.atlassian.com/cloud-automation/docs/jira-smart-values-insight/
Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Tank you @Joseph Chung Yin
The link you refer to doesn't mention ${customfield_12345} for example, which does work for me - but only when that custom field is also an insight field.
Besides other Insight Object custom fields, are there any other variables / replacement values we can use in Filter issue scope (IQL)? Looking for anything we can use from the issue to include in the IQL
