When using linked issues - screenshots are not showing on the new ticket
Efrat Barak Zadok May 10, 2023
When I create a ticket to our R&D team I am doing the following -
I click on Link issue - choose + create linked issue and then I choose the Jira project and populate some of the fields.
I noticed that the new created ticket is not showing the screenshots I added to my original ticket. Any solution here?
3 votes
Michel Neeser
May 10, 2023
Hi @Efrat Barak Zadok
Did you check the checkbox "Copy attachments" in the dialog where you populated the fields for the new/linked issue? If you do so, the screenshots should be copied to the new ticket as expected.
Thanks @Michel Neeser - do you know if I can have this checkbox checked as default?
Michel Neeser
May 10, 2023
@Efrat Barak Zadok I don't think that is possible without browser plugins or third party apps, as this checkbox is a standard checkbox from the system itself.
FREE
