asset manager help
Rustam Piriyev July 26, 2022
Hi!
I need help to choose asset manager in Jira (JSM-CLOUD) witch is syncing and can take device info från Azure AD or endpoint manager. Witch Plugin(app) you can recommend?
Mark Segall
July 26, 2022
Hi @Rustam Piriyev - You may want to consider moving up to the next tier of licensing (Premium) which comes with Insight.  Insight is quite powerful for asset management, tightly integrated with the rest of Jira, and supported by Atlassian.
Rustam Piriyev July 27, 2022
is that good for jira cloud too?
Mark Segall
July 27, 2022
Yes.  Insight is included with cloud premium.
Like Rustam Piriyev likes this
so i can get my device list from intune(mdm) or azure ad with sync? and I dont need add assets by hand?
Mark Segall
July 27, 2022
Correct - There's a little bit of upfront work, but you can establish some integration to have that information populated in Insight.
Dimitri Cools
I'm very curious to what you mean by this ?  Because as far as I can see there's no way to integrate / sync..
which is really causing issues for us.
They do have a solution for Data Server;
https://marketplace.atlassian.com/apps/1218974/assets-azure-integration?tab=support&hosting=datacenter
Mark Segall
February 17, 2023
Correct - You need a custom integration for cloud.
Dimitri Cools
As I'm forced to go that route, do you maybe have some tips or can you elaborate on how you approached this?
Mark Segall
February 17, 2023
Unfortunately, I only led the effort strategically.  I don't have the deep technical knowledge of the Microsoft APIs so I'd need to defer to someone else.
Matej Štrba
Hi everyone,
Great news for all of you!
We have recently launched an app called Azure Sync for Jira Assets, which is available for the JSM in cloud version.
This app provides seamless synchronization of Azure resources with Jira Assets.
You can find and install the app directly from the Atlassian Marketplace here.
We developed this app in response to the community's need for a cloud-based integration solution, and we’re excited to offer it to you.
If you have any questions or need assistance with the setup, please don’t hesitate to reach out.
Best regards,
Matej
