auto coment when issue is assigned from unasigned status
Vasco July 8, 2025
I'm looking to create this automation to comment when a ticket is assigned to agent, but only when it was previously unassigned.
I was thinking to use the trigger "When item assigned" but I do no see a way to identify the change...
Is this possible?
Benjamin Črnjak
Hi @Vasco ,
you can go ahead with your idea, and the only thing you need is smart value {{fieldChange}}.
Using that smart value, you can easily get previous assignee. And then use IF block to check if previous value was  EMPTY.
here is a documentation.
kind regards,
Benjamin
