×I need help with importing csv files and linking objects.
I have two csv files: customers and (as a child of customers) employees of the customer:
Customer object Attributes:
Name (type standard, text), customer number (type standard, integer)
Employee object Attributes:
Employee name (type standard, text), CustomerNo (type standard, integer), Ref customer (type object, object customer, reference)
The customers were all imported via csv. When importing the employees, a link should now be created between the customers and the employees via the customer number (Customer) / CustomerNo (Employee).
I have mapped the fields when importing the employees via csv:
csv.name > employee name
csv.customer number > CustomerNo
csv.customer > Ref customer (AQL: CustomerNo ={CustomerNumber})
How can I ensure that the Ref customer field is linked to the customer during the import? I allready tried several AQL-statements but had no luck.: CustomerNo = CustomerNumber, CustomerNo = ${CustomerNumber}
I would be delighted to receive a tip.
Hi @Heiko Lotz
I think the AQL might be this if I'm understanding your screenshots correctly
"customer number" = ${CustomerNumber}
Hi @Heiko Lotz and welcome to the community,
While using the AQL to bind objects you have to keep this in mind. E.g. you have this AQL:
CustomerNo =${CustomerNumber}
CustomerNo should be the insight attribute and
CustomerNumber should be the column name of your csv.
That would be the case for 1-to-1 mapping. Make the corrections and try again. Let me know how it went.
Hello an thank you !!!
Now I am totaly confused. This is what it looks like:
ATTRIBUTES OBJECT CUSTOMER
ATTRIBUTES OBJECT EMPLOYEE
IMPORT-MAPPING
employees.csv
Name; CustomerNumber
Anton A;10001;
Berta B;10002;
Caesar C;10002;
Daniel D;10003;
Emil E;10001;
Fridolin F;10002;
Gerda G;10004;
It is still not working. Dont know how to link the objects.
Hi @Heiko Lotz try "customer number" = ${CustomerNumber}, that is the attribute "customer number" contains numbers just like the csv (e.g. 10001, 10002 etc).
You are totally right! That is the solution!
Thank you so much :-) You made my dax.
