difference between external and internal customers
Rim Ben Rejab
hello guys,
someone asked me what can internal customers do that external customers don't.
does anyone have an answer? :/
thank you so much
Christian
June 11, 2024
Hello
The primary difference is visibility to customers. In the customer portal, Internal comments are not visible, while external comments are.
In terms of functionality, they are the same. The comments have the same features weather internal or external. One benefit to internal comments is that if your instance of Jira has other licensed users, say for Jira software, that do not have a JSM license, they are able to make and read internal comments assuming your privilege scheme is setup correctly.
I hope this helps!
Christian
Rim Ben Rejab
thank you christian ^^ I appreciate your help!
