if Daily processing time for automation rule is breached
Neeraj Kumar October 16, 2020
if Daily processing for automation rule is breached then is the pending rules will execute in next slot of 12hours or not.
Daily processing time is project specific or global.
Please refer below table for more clarity.
The following automation service limits have been applied to ensure the performance of  instance.
Summary
Limit
How might this limit breach?
Components per rule
65
A single rule contains more than 65 conditions, branches and actions.
New sub-tasks per action
100
A rule executes the creation of over 100 sub-tasks.
Issues searched
1000
A scheduled JQL search that isn't streamlined enough and returns more than 1000 issues.
Concurrent scheduled rule executions
1
A scheduled rule that takes longer than 5 minutes to execute, scheduled every 5 mins. Only single concurrent executions of this rule is allowed.
Associated items for a rule
5000
Defines how many items a single rule execution can fetch.
For example, a fetching 100 issues, followed by a related branch fetching 10 subtasks per issue, would add 100 * 10 = 1000 associated items to this limit.
Items queued globally
50000
Similar to Items queued by rule, but applies to rules in progress across your Jira instance globally.
*Daily processing time
60 min per 12 hrs
A rule executes every 5 mins and each execution takes longer than 5 seconds. This could be the case, for example, if your rule talks to slow external systems.
Loop detection
10
This controls how many times a rule can trigger itself (or other rules) in quick succession before the execution is stopped and marked as a LOOP.
Kian Stack Mumo Systems
Neeraj,
Based on reviewing the documentation, I believe that the processing limits apply to each rule individually. If it does breach the service limit, it'll queue it up to run when it next has bandwidth. If it queues too many of those rules, it will automatically disable the rule to prevent it from piling up. Does that help?
Kian
Dan Knapton July 17, 2024
Can this be confirmed by Atlassian?
Dan
